Old December 1st, 2008, 22:23
The Lure Washer The Lure Washer is offline
Re: Loud Clunk When Putting Into Drive
glad you figure that out
Last edited by The Lure Washer; December 1st, 2008 at 22:25. Reason: i didnt read all posts
Old December 2nd, 2008, 11:26
GTABurnout's Avatar
GTABurnout GTABurnout is offline
I am having the same problem but my cherokee is a 2000 with only 34K on it I guess I will replace the u joints and hope for the best.
Old December 2nd, 2008, 11:38
heyjpark1's Avatar
heyjpark1 heyjpark1 is offline
Should there be zero play in the drive shaft? I, too, am getting a bad clunking when i hit the gas and let off the gas.
Old December 2nd, 2008, 13:27
GTABurnout's Avatar
Ok I have been reading everythibng I can about this issue. I am starting to think I may need to do the STY since I have a 4" lift. Man I am ready to drive this thing in to a wall and buy a toyota...
Please help...
Things I will check tomarrow morning.
U-Joints
Tranny mount.
Pinion angle
???(Anything else)
I need to get rid of this clunk....
Old February 11th, 2018, 20:02
soyjer soyjer is offline
Originally Posted by J33PsRock View Post
So...turns out it was the rear U-joint. I am such an idiot. I was thinking big $ for a transmission or a differential rebuild or something...and it was a $16 u-joint.
I couldn't tell that there was any play in it before, then I just changed it...fixed the problem. Thanks fellas.
I just bought a stock 1999 XJ, never been off road or abused, 97K mileage...all u-joints, engine/transmission mounts seem good, and yet it clunks and lurches when put into any forward gear, but not at all when put into reverse. Did yours clunk when put into reverse, or only when put into a forward gear?
Very loud front-end clunk when turning SpenceXJ Modified Tech Discussion 28 August 26th, 2008 13:55
Lurch when putting into drive? darjevon OEM Tech Discussion 3 May 11th, 2007 10:17
Drive train clunk oldebrush OEM Tech Discussion 5 May 23rd, 2006 23:53
Loud noise in 4 wheel drive Lunatic728 Modified Tech Discussion 0 November 14th, 2005 05:41
Loud clunk in the night... 4xBob Modified Tech Discussion 0 May 6th, 2005 23:45
