Old February 12th, 2018, 19:07
Silverstone XJ Silverstone XJ is offline
Floor Pan 2000 XJ
I need new floor pan for rear trunk . I can't find any supplier ? So far all I have found is 98 model ??? Wondering if it will fit or do I need exact match .
Anyone seen a rear pan for a 2000 ..
Thanks !
Old February 14th, 2018, 06:29
Stallacrew's Avatar
Stallacrew Stallacrew is offline
Re: Floor Pan 2000 XJ
I don't have a Jeep newer than a 1990, but I feel sure that all the metal pans should be swapable. Maybe someone else can chime in and confirm or have a picture under their carpet. Anything 87-01 should interchange.
Old February 14th, 2018, 09:44
RCP Phx RCP Phx is offline
The 98 should work, the changes were in the 97-01 years with the change being the rear sheetmetal for the plastic gas tank and new pump/sender.
Old February 14th, 2018, 11:08
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
97-01 is all the same sheetmetal. I agree that anything 87-01 the floor pans should interchange
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Exhaust Manifold Adapter Pre 2000 to 2000+ markjrs3 OEM Tech Discussion 5 January 11th, 2016 09:03
through the floor Q's alek21 JeepSpeed, Prerunner and Competition Tech Forum 51 May 21st, 2010 07:40
will a pre-2000 4.0 bottem end swap into a 2000 XJ? semisynth OEM Tech Discussion 8 June 1st, 2006 10:39
2000-older head on a 2000-newer engine? JONNYD Jeep Street and Performance 8 June 11th, 2005 08:04
Head Swap Pre-2000 vs. Post-2000 JONNYD Modified Tech Discussion 1 June 10th, 2005 10:30
