Old March 3rd, 2015, 16:35
bugout's Avatar
bugout bugout is offline
Location: Florida EVERYDAYS forcast: Hot and humid with a 50%chance of rain.
Re: Junkyard upgrades
Thanks!!!
Old March 3rd, 2015, 16:42
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Originally Posted by dukie564 View Post
#1 - I have one in my shed but haven't installed it yet. The "upgrade" one is from the hydraulic fan v8 model - and provides greater line pressure to turn big meats. Can't go wrong?
The WJ pump definitely supplies a lot more pressure...
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231 8.25/D30 ARB's 4.56's 33's deavers and a few other things.
Click here to join the red team
Old March 3rd, 2015, 16:45
bugout's Avatar
[QUOTE=sidewaysstarion;246206893]
The WJ pump definitely supplies a lot more pressure...[/QUOT
What happened? Can the stock XJ line no handle the pressure????
Old March 3rd, 2015, 19:35
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Did you drill out the restrictor? Curious if that was a factor.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old March 4th, 2015, 15:50
Lurch Lurch is offline
Here's what I had to go through to get mine to work:
http://naxja.org/forum/showthread.ph...highlight=pump
Sideways has this setup now. I was very happy with the results once i got it dialed in. I got pinhole leaks in two high pressure lines, both which had 100,000+ miles on them, BEFORE I ever bored out the fitting. Once I swapped in a new line and added the cooler and bigger return line, it was never a problem.
Old March 4th, 2015, 16:02
dukie564's Avatar
dukie564 dukie564 is offline
Bacon...that is all
interesting. Thanks for that
1995 XJ Cherokee Sport
4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
4.5" Frankenstein Lift, 35x12.5 Cooper STT Pros
346,000 mi and runnin' strong
Old March 5th, 2015, 10:47
Coffee Drinker
I'm still running a 3/8 return line to a 3/8 in and out cooler. I bought Lurch's 1/2" cooler and hope to have it installed shortly, but with the WJ pump and a stock box I can turn 33's no problem in the rocks.
Old March 26th, 2015, 08:56
keganhensley keganhensley is offline
So I got through 8 or 9 pages before wheels started turning and thoughts started burning. If junkyard s10 leads offer an extra 3.5 inches of lift, can I order a 3.5 inch lifted leaf for an s10 for a net gain of 7 on my xj? Or did I miss something?
Old March 26th, 2015, 09:03
dukie564's Avatar
Bacon...that is all
why wouldn't you just order the correct leafs for your truck?
the S10 leaves don't bolt in - the length and centering pin locations are wrong. You basically disassemble the leaf pack, cut the eyes off the main leaf, then attach it below your stock XJ main leaf.
3.5" S10 leaves would have way too much arch in them to use in this configuration
Old March 26th, 2015, 20:14
Without having done research as far as pricing I could make an assumption that 3.5 inch s10 leads are cheaper than 7 inch xj leafs. Just a thought
Old March 27th, 2015, 10:46
dukie564's Avatar
Bacon...that is all
still, the arch will be too great to stick below a stock XJ main leaf. Good recipe for a dump truck ride and a broken main leaf
Old February 14th, 2017, 16:07
dasbulliwagen's Avatar
dasbulliwagen dasbulliwagen is offline
Bump... just because i like this thread so much.
Old October 12th, 2017, 20:29
Dirty Offio's Avatar
Dirty Offio Dirty Offio is offline
Subscribing, so I can find it again as needed! lol
Old October 13th, 2017, 07:22
burntkat burntkat is offline
NAXJA Member #1145
You guys DO realize you don't have to reply to subscribe, right?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 17th, 2017, 07:14
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Subscribing.
What?
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Upgrades, upgrades!!! Missiletech Modified Tech Discussion 5 August 27th, 2008 16:55
cheapest junkyard coiks for 3 inch lift dellstopjeep Modified Tech Discussion 11 July 28th, 2005 22:56
Junkyard goldmine? 88woody Non-Tech / Off Topic 20 October 29th, 2004 15:41
Overheating after a bunch of engine upgrades XJVenom Modified Tech Discussion 34 May 17th, 2004 18:40
brake upgrades? 540ismiley Modified Tech Discussion 4 October 5th, 2003 21:14
