Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old September 14th, 2017, 13:57
The1AndOnlyBug The1AndOnlyBug is offline
Re: no bus, no gauges, no crank.
So... the guy at the garage tells me that he hooked a jump pack to it and the jeep started right up...... he said my battery is junk and once I get a new battery then he can test further.... what doesn't make sense to me is when I jumped it last night it made it do a no bus again....
Old September 20th, 2017, 17:38
We'll the jeep is back on the road, believe it or not it needed a starter.... the solenoid crapped out and must have been shorting out the pcm... He replaced the starter and everything else went away... I no longer have a "no bus" the cel just came back on after 25 miles, I'll find out what that is tomorrow.
Wether or not that was the root of the whole problem remains to be seen....
Old September 21st, 2017, 14:48
Ok, so the jeep runs a little rough, I'm gonna start with the O2 sensor. The running lean should be fixed once I replace the intake (P.O. over tightened the bolts and cracked it) any other places I should start?
I also tested the TPS and at w.o.t. it wouldn't go over 3.25V I tested the old TPS which tested fine so I reinstalled the old one.
232 crank vs 258 crank | race stroked motor Nick675 Street and Performance 3 September 2nd, 2009 17:25
94 gauges in my 96... Will the gauges pin if I have low oil press. or am too hot? Plays For Jeeps Modified Tech Discussion 0 March 14th, 2007 18:57
Crank crank crank crank crank vroom gone postal OEM Tech Discussion 27 November 25th, 2006 09:47
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 17:33
01 gauges and check gauges light Ramsey OEM Tech Discussion 2 October 6th, 2004 23:01
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
