Old September 16th, 2017, 08:22
md21722 md21722 is offline
Re: Low Oil Pressure
Originally Posted by cgross220 View Post
Thanks everyone. I haven't checked with a mechanical gauge but will do as soon as I can get over to an auto parts store. I'm also going to throw in some 10W-40 oil either way just since it sounds like the 4.0s like it more anyway. I definitely may try the HV oil pump; it's spent the past 1.5 months out of the 3 months I've had it in my garage so at that point unfortunately I'll probably just unload it and see what I can get
You really need to verify with a mechanical gauge.
Typically on the later years 2000-2001, the head cracks, leaks coolant into the crankcase and wipes the bearings. Coolant is very corrosive to to the cam & crank bearings. Even 1-2% contamination with oil can wear them. It sounds like your coolant loss was external so not the same problem. Also, owners typically need to go through a lot of coolant before they report low oil pressure.
Separately, overheating will typically cause a 0331 head to crack. It might be a small leak and not contributing to your low oil pressure. Look for traces of green or any coolant stains by removing the oil filler cap and looking straight down. That's where they crack, right there between the #3 - #4 rockers.
Renix pressure bottle coolant pressure tester knever3 OEM Tech Discussion 8 October 14th, 2012 05:10
Diagnose AC system? Low pressure good, not so much on High pressure Magus2727 OEM Tech Discussion 14 June 26th, 2011 14:17
Oil pressure gauge malfunction or oil pressure spike? Daedalus454 OEM Tech Discussion 5 August 5th, 2008 21:09
Pressure switch that closes once a minimum pressure is reached?? twisted_ed Modified Tech Discussion 6 November 28th, 2006 10:14
Low oil pressure warning system and oil pressure back up Q's Bones Modified Tech Discussion 7 June 19th, 2003 20:31
