Hi guys, I am attempting to remove my TC today to install my SYE and its giving me fits, does anyone have any tips or tricks? Also what is the best tool for removing the bolts?
No need to remove it unless you want to.
The two SYEs I have installed were done with the transferase still installed.
The case can be split in place. http://www.jbconversions.com/pdf/16-1205.pdf
Ditto on the stubby wrench. I also used 450 lb. transmission jack from Harbor Freight (item #61232, $80 with a coupon) to support it when removing and installing. I found it a lot easier to work on the TC on a workbench.
I used my floor jack and lowered the trans/transfer case to get more access at the top. Also using 1/4” drive sockets, extensions etc help get into tight places. I much preferred working on the bench then under the Jeep.
Pop off the shifter linkafe, put a jack under the transmission mount, unbolt the cross member from the frame rails, and lower it a few inches for increased clearance. Use a stubby wrench and/or a super long extension with a ratchet and socket. TC to transfer case nuts are 9/16" IIRC.
