Still having charging problems
Drew00
indiana
If the voltage regulator is bad inside the ECM and your alternator is good can you put an external regulator on in instead of replacing the ECM?
Have you inspected the alternator brushes ? Worn brushes will test "good", but not charge properly when on the road.
