My first post here but I've been lurking awhile.
Replaced water pump, thermostat and flushed cooling system. I did get a new pump from orielly and suspect that it is the culprit. Did burp the car after all the work.
Overheats while cruising but cools down when revs increase. I suspected a fan issue but it will overheat cruising at 50mph (once again cools down when given lots of throttle). Defroster/heat is non existent at idle but increases when driven.
Any thoughts?
Any thoughts?
