Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old November 19th, 2007, 21:39
xDUMPTRUCKx's Avatar
xDUMPTRUCKx xDUMPTRUCKx is offline
turning smooth body shocks into threaded body coilovers
anybody know who provides this service?
im seeing what can be done with my king 2.5" remote resi shocks.
Old November 19th, 2007, 21:55
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
Re: turning smooth body shocks into threaded body coilovers
you should probably just give them to me hehe
You can get all the parts directly from King, it may not be cost effective as you would have to buy the threaded shock body, and I doubt they are cheap, but you can also get the coilover hardware and springs, the guys at King are really helpful, they are not hard to disassemble to transfer the guts to the new body though. What are your plans with the coilovers?
Old November 19th, 2007, 22:26
i thought they just ran a die over the body or something
i got these for a smoking deal and they are going to be perfect to use as shocks for now on the back of my buggy but i thought it would be nice to think ahead for when i come back from deployment and do a tri-four link in the rear.
Old November 20th, 2007, 09:21
C85D4x4's Avatar
C85D4x4 C85D4x4 is offline
NAXJA Member #1311
The body in a regular shock would be too thin to support the weight of any vehicle….......especially one that has been threaded
Maybe you can sheave it with tubing that has been threaded on the outside, it may be possible
But your probably better off selling the shocks and buying coilovers
Old November 20th, 2007, 10:09
Skullver's Avatar
Still Flailing
those aren't "regular" shocks by any means. They use the same material for both smoothies and coilovers but they turn the threads onto the coilover bodies, I can't see that they would use a die to cut them. Sleeving is a bad idea as it will seriously degrade the heat transfer. I would call King and just ask them how much for just the threaded bodies, and go from there.
Rate This Thread:
3" coils/shocks and 60mm Bored Throttle Body BBeach For Sale: Private Party Only. XJ ITEMS ONLY 6 January 9th, 2007 21:17
Bored throttle body injection body? Schris1 Jeep Street and Performance 3 January 2nd, 2007 21:02
painted grill to match body/body touch-up 97xjstock OEM Tech Discussion 2 April 3rd, 2006 22:03
What's the down side, Threaded Body Air Shock??? FarmerMatt Modified Tech Discussion 1 March 3rd, 2005 15:13
Body flex and shocks... witty OEM Tech Discussion 6 May 22nd, 2003 14:58
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
