Aquit45
- Oak Hills, Ca
Hey guys have a 1990 Laredo with 180k on it. I took it for a smog test in California failed high no.
Went on to replace every sensor is functioning as it should. Took it back failed again in replaced the egr valve and egr solinoid. Now with engine running the egr solinoid is supposed to block vacuum to the valve at idle. From what I read the ecu send a ground to the solinoid when the egr is not needed. So I'm not getting a ground to the solinoid at all. Any ideas is there is broken wire in the loom somewhere.
