2wd to 4wd
Riley/MN
I'm sorry, I'm sure this must've been covered, but my search parameters must be off..
I am stripping a 93 to get the motor, but everything else is there, the body is shot. I am going to look at a 94 2wd tonight. I am thinking the swap should be fairly easy, right?
Thanks
~Riley
Transmission
Transfer case
Shifter assembly
Front axle
2 driveshafts
As long as you aren't worried about the indicator lights, which may be a non issue on a 93/94, not sure, then it is that easy yes.
Using an aftermarket shifter instead of the crap factory one makes it a LOT easier.
Transmission
Transfer case
Shifter assembly
Front axle
2 driveshafts
Yep, that's it, and having a full parts vehicle there to grab everything from makes it a lot easier, and being of similar years, even more so!
I just got done swapping everything from a 91 to a 96 and had to change several sensors engine wise, and a friend and coworker swapped everything from said 96 to a 2wd 98 and converted to 4wd and also had to change some sensors. There's a story there, but this is your thread, so I'll just point out that the only things we ran into were with the motor, so swapping everything else will be a direct swap. I will mention later models do have differences in the transmissions, but that won't be an issue for you.
