neatjeep
- St.Charles MO
So today, I've got noise coming from under the hood. I tracked it down to the AC compressor (only screams when AC is OFF - Turn on AC and its back to normal - didnt notice it screaming as clutch would engage/disengage during normal operation, but will listen for that on next drive).
Research here and elsewhere has me looking into replacing the clutch assembly or bypassing completely until next summer and then just replacing the whole compressor.
I need a bit a quick advice on the following points:
1. Should I drive it? I have a 38 mile commute and im fine with running AC the whole way, but what if it starts screaming when clutch disengages off an on... How much damage can I do?
2. If I decide to bypass, is there a shorter belt that I can run so I dont have to remove the compressor and put in a bypass pulley?
3. If I have to remove the compressor, do I really need to take it to a shop to do this? (im totally ignorant on the topic but I know that refridgerant is nasty stuff)
Trying to figure out order of operations here, and take the least expensive short term route, but likely planning to replace entire compressor in the spring when I have a bit more cash flow.
**edit - forgot to mention, the compressor is a Sanden U4691, from what I understand there ARE kits to replace the clutch assembly. FWIW I have had zero other issues with AC, ice cold all the time.**
thanks guys!
thanks guys!
