Tally_XJ
- Tallahassee, Florida
Since I changed to the Rubicon Moab 16" alloy wheels my factory wheel studs have been too short. The hub of the Moab wheel itself is thicker.
I kept breaking and stripping the lugs because I did not have enough thread purchase to properly torque the wheel nuts down.
I tried to change to a 9/16" x 18 lug stud but the lug stud shoulder was just too large in diameter to fit through my axle hub holes.
After several attempts with some various studs and looking through the Dorman products catalog I found a great solution that should have been clear as a bell to begin with.
All Cherokee, Grand Cherokee and standard Wrangler has the same lug studs from the factory. They only change to a different stud if the vehicle came with and alloy wheel.
The factory studs are 1/2 x 20 threads, 1 5/8" long with a front knurl diameter of .623 and a rear knurl diameter of .621 thousandths.
The replacement stud I found to work very well is the studs from the 2003 Wrangler Rubicon.
These studs are 1/2" x 20 threads, 1 15/16" long and have a knurl diameter of .627 thousandths. The larger diameter of the knurl still pulls through the axle hub easily enough and makes a very good tight fit that won't work loose. The longer length is perfect.
The Dorman part number 610-449 is also a hardened stud with a black industrial finish.
