Old October 5th, 2017, 15:58
Tacowhip's Avatar
Tacowhip Tacowhip is offline
Body mouldings
Hey guys, the previous owner removed the factory door mouldings on my 95. It has that nasty 2 tone look to it. I've seen some of you guys remove the moldings and have it nice and clean under that body line. What are you doing and using to get that clean look? Spray bombing black, or vinyl?
Old October 5th, 2017, 22:01
lawsoncl lawsoncl is offline
Re: Body mouldings
I've seen a few guys tape it up and roll on black bedliner. A local marine shop might carry similar molding in rolls if you're looking to replace it.
Old October 6th, 2017, 11:19
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: Body mouldings
That's a pretty good idea, hadn't thought about that.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old October 6th, 2017, 16:56
lawagoneer lawagoneer is offline
Re: Body mouldings
I used bedliner.
Old October 7th, 2017, 02:00
Ralph77 Ralph77 is offline
Re: Body mouldings
I had mine Line-X'ed with a few other things. Can't post a picture but one can be seen here of my door moldings. Post # # 88747
http://www.jeepforum.com/forum/f177/...l#post38881090
Door mouldings Tacowhip OEM Tech Discussion 3 May 28th, 2017 15:42
Side mouldings cj11 Modified Tech Discussion 27 June 12th, 2009 20:33
FS: 01 sport side mouldings spcustoms For Sale: Private Party Only. XJ ITEMS ONLY 0 February 26th, 2007 17:20
Briarwood decals, mouldings Markus N. OEM Tech Discussion 4 January 13th, 2006 19:01
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
