I have a 1990 XJ 4.0 Pioneer AW4
This morning I turn on the AC and it comes on for maybe three or four seconds, and then shuts off. Heater doesn't come on either. So I pull into Shucks and check the fuse. Sure enough, it's blown. I replaced the 25amp fuse, turned the AC on; it works for about three seconds, and then blows the fuse again.
Any idea why this is going on?
Only thing different I have done is yesterday I wired in a fan switch to the orange wire going to the relay, and got the power for the switch from the fuse panel. While I was doing this, the top of my hand brushed against the small light bulb under the driver side dash. After I made contact it started to glow really bright. Then the "area" of the light started smoking pretty good. I undid the battery cable ASAP and removed the bulb.
No idea if all of this is just coincidence, or not.
Anyway, it is HOT over here, and need to get my AC fixed. Any ideas?
