seanyb505
- Simpsonville, SC
I'm redoing all the steering today(yesterday)because it's insanely loose at the wheel. 97, 2wd so no axle business up front. Everything was going smoothly until I got to the ball joints. I figured out I just needed more force but then they came out. With severe persuasion. With more persuasion I was able to install the ball joints just fine again. I have the rental press, worked, but with persuasion, and trial and error on which pieces to use.
Now that everything is going back together I've got some problems. The dust boot won't fully seat on the lower joint on either side. It's just a dust boot with no structural stress, so on is good enough right now. I started with the passenger knuckle and here's where the fun starts. There is about half an inch not fully seated into the top of the knuckle. The bolt has been torqued, did I just get the wrong part number? I double checked it a few times, K3134T.
The other thing making me second guess everything is that now that the ball joint nuts are torqued and I've hit both with grease, I can barely rotate the steering knuckle by hand. While is wasn't super loose before, it definitely wasn't this hard to turn. I have to put a lot of muscle in to rotate it, and I'm not sure if this will be okay for the steering system when/if it all gets back together. The studs are spinning, but something still seems off.
Anything I may be overlooking?
Edit: per what I found in the FSM I torqued the top ball joint castle nut to 75 and the lower to 80. Backing them off helps the knuckle rotate easier, but I don't intend on leaving it like that.
