Ok, so i bought an xj a few months ago with a bad trans. Once i put new trans in i drove it down the road and it was misfiring a lot on the bottom end of the rpm range, but seemed to do fine at full throttle. After driving a while longer it cut off on me and wouldn't start back until it cooled down for about an hour. So far i've replaced the plugs, wires, air filter, rotor button, ignition coil, pick-up coil and still nothing. Now it won't start at all. The ignition coil is putting out power but the power doesn't seem to be getting to the distributor. I'm not sure where to go from here so if anyone has any experience with these or could help out in any way it would be greatly appreciated. Thanks
