Boulder_jeeps
- Lafayette
I have the 6 cylinder (not the HO) and it has a whistling noise coming form the front. I open the hood and noticed the vibration damper was wobbling and the noise seems to come form that area. Is there a bearing in behind the damper? Im not sure if it is loose I will check that in the AM. Is a wobbling damper common on the 6 cylinder?
