Old February 2nd, 2012, 17:48
CherokeePride99 CherokeePride99 is offline
HP Dana 30 Pattern Check.
This is my first r&p install. After installing the pinion i noticed it had to be moved back but all there was behind the pinion race was an oil baffle. it was .020 so i put in .015 worth of shims.after that it was still too deep. so i removed some more and it still was too deep.so now i have no shims. is this pattern runnable or do i need to find a thinner oil slinger? i dont think i should remove the slinger all together. any thoughts fellas?
Drive
Coast
Old February 2nd, 2012, 17:57
Porch951 Porch951 is offline
Re: HP Dana 30 Pattern Check.
Pics no workie for me?
Old February 2nd, 2012, 21:58
stroked88's Avatar
stroked88 stroked88 is offline
cant see the pics, but make sure that your bearing races are fully seated, along with your pinion bearings being fully seated. You shouldnt have to find a thinner slinger if everything is in properly
Old February 2nd, 2012, 23:20
XJ jay XJ jay is offline
pics are working for me, but considering i was asking for help a few days ago my opinion isnt worth much. id say your hair deep on your pinion, take out .001-.002 and try again, but my pattern was a little deeper on the pinion but is running quiet. how think is the oil slinger between the big pinion bearing and the pinion, also you need to run the baffle between the large pinion race and housing as its required in a HP to keep the front bearing well lubed. the original slinger i got was .060 but my overhaul kit came with a .030" thick slinger. the pattern is very usable, but you need the baffle and the 2 slingers.
Old February 3rd, 2012, 06:22
Here's a link to photobucket. Hopefully these pics work.let me know
http://s1271.photobucket.com/albums/...130_115139.jpg
And the pinion is fully seated. I used a setup race.
Old February 3rd, 2012, 06:33
Oh and my oil slinger is ..060. I was gonna keep the oil baffle out but if you think it gotta be in there then im gonna have to get a thinner oil slinger. where would i find one about .030? the ones i see dont have any measurements.
Old February 3rd, 2012, 09:09
.030" slinger came with my overhaul kit, check the net or maybe some local drive line shops and yes you absolutly must run the baffle, it holds oil for the small pinion bearing, if you remove it you will starve the small pinion bearing of oil and youll have to repete this process
Old February 3rd, 2012, 10:46
Called randys there Yukon slinger is .031. Ordered that and a new baffle too cause the other one got damaged. I'll post more pics when I get the new slinger installed.
Old February 3rd, 2012, 14:01
menos menos is offline
I think the factory set up some dana 30's with a thinker oil slinger instead of using shims behind the race. I just rebuilt mine and I had a .065 slinger in there with no shims. The rebuild kit came with a .031 so I used that and was able to stack shims behind the race to properly set the pinion depth.
Old February 3rd, 2012, 16:47
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
That is about .003-,005" too deep. I have had to leave out the baffle behind the bearing cup on one before because it was too deep with no shims. If you can get a thinner baffle that would be good.
Old February 3rd, 2012, 17:25
have you measured the thickness of the larger slinger, if its the factory one im inclined to say its around .060". i think the baffle is as thin as it gets at .020". i wrecked mine when i punched the old race out too, but i sanded down the old pinion race with a roll-lock disc on a air grinder to make a set up race so i wouldnt trash the pinion baffle. measure your old slinger and subtract .003" and use that as your starting point for total pinion depth shim, that should pretty much put you bang on for PD, shim your backlash accordingly to get you .006-.010"(i kept mine tight at .007") and you preload and lay some marking compound.
Old February 3rd, 2012, 22:39
Xj jay I think your right on. the baffle is .020 and the slinger is .060. So if I use the.030 slinger and plus the baffle I will have .010 to play with. So I'll just add round .007 to the shim pack and I should be pretty dead on right?
Old February 3rd, 2012, 22:50
Yes, .057" would be your next step, set your backlash and lay a pattern, but be prepared to have add or subtract another .001" if you want that perfect pattern you've hurd so much about.
Old February 4th, 2012, 07:25
bobnoxious's Avatar
bobnoxious bobnoxious is offline
I agree that your pattern looks .003-.005 deep.
Double check that everything is seated correctly...you need the slinger under the bearing on the pinion, and the baffle/dam behind the race in the housing for proper oiling/oil retention.
Old February 9th, 2012, 20:59
I got a thinner slinger and a new oil baffle. How this look?
Drive
[IMG][/IMG]
Coast
[IMG][/IMG]
D30 Pattern check menos Modified Tech Discussion 30 January 27th, 2012 17:36
Dana 44 Gear Pattern Check Please Begster Modified Tech Discussion 25 July 31st, 2008 20:51
D44 Pattern Check Please racer32 Modified Tech Discussion 8 April 20th, 2008 01:27
pattern check please massxj Modified Tech Discussion 7 May 16th, 2005 22:05
Please Check my D30 Pattern ChuckD Modified Tech Discussion 20 March 22nd, 2004 21:08
