HITDOGG
- Bostic, NC
First post here guys. And I do realize there are probably a blue million threads on this same subject. I tried searching, but for some reason my tablet don't like that, so here goes.
Bought my first XJ a couple of weeks ago. 1996, automatic 4 speed, 4wd, 91000 and some change on the clock. The guy I bought it from said that it would take spells where it wouldn't crank. Found out today what that meant. Full electrical power or it seems, but the starter acts like it wasn't getting voltage.
The guy I bought it from said that he had it at a mechanics a couple of times but to no avail. From what I have been able to find on the web, it could be a couple different things. Ignition switch, or neutral safety switch. The ignition switch has been replaced according to the guy I bought it from and it has a new key. I'm not sure if the electrical part or the connecting rod between the key and switch was replaced.
So today when I go to leave work, nothing doing on the cranking front. I tried giggling the shifter to neutral and park, nothing. Tap on starter solenoid. Nothing. So I had read something about a Crank Position Sensor, so not knowing if that would cause a no start, I unplugged it. I also disconnected the battery. Left them both for about 10 mins. Connected every thing back up, and bam sucka, it started right up.
That's where I'm at. After getting home, fired up every time. Any thought or suggestions would be greatly appreciated
