High Idle to often
SINCITY192
Bronx, NY
its winter and every time i drive, then shut off the car and turn on the car again the idle goes really high about 3000 sometimes shutting it down works or helps but alot of times it doesnt whats wrong these arent factory sensors (TPS and IAC) i replaced them already the TPS a couple of times. So what is it? Sometimes sitting still after driving it sought of surges up a little! If that helps any!
what year is your jeep? most likely vacuum leaks
vacuum lines are always breaking and coming loose on those older jeeps. check the distribution tree by the air box, could be coming from there.
You mention that you replaced the idle air control but did you thoroughly clean the part/port where the idle air control seats? Good idea to thoroughly clean it with q-tips and throttle body cleaner.
It gets very carboned up over time and miles and could give you idle issues even with a brand new IAC.
Do you still have your EGR hooked up? If not, test it.
I can post the test procedure if you need it.
