88 MJ front shaft length issues
I'm not sure what to tell you . I have 3 MJs , 2 have 231s and one has a 242 . The 2 autos have the same driveshafts and the two different tcase. The manual 231 MJ has a shorter front shaft , which may fix your problem.
Interesting. I did not know that. Good info since I will be swapping a 242 into my MJ and a 231 into my xj. Thanks.
I'll need a new shaft for my xj bc the comanche is a 2wd currently.
I do have a stock 231 driveshaft from annother jeep but it has a manual so that probably changes things there too... lol
