Though I'd share my cowl hood build.
Stripped down to metal.
Marked for the cut.
Cut.
After goofing with the stock hood you relize how flimsy and thin they are. Just cutting and adding strips wont give the hood the strength it needs to hold its shape properly. I used a stick of .25" rod and formed the profile I needed for both sides. These were tacked to place. Next I welded uprights using the same rod to the frame work to support the cowl.
Job well done, reward youself.
Next I used some masking tape to create a pattern.
I cut it out (a little large) and fit it.
After that I ran it through my english wheel to give it some curve and bead roller to roll the shoulders. You don't need these tools to do this but it helps.
Marked for the cut.
Cut.
