RRC Rig of the Month
x2elite
Texarkana, AR/TX
So the folks at the top of the :NAXJA: food chain have decided to do something a little different for the March ROTM. In Feb each chapter will do it's own ROTM (Rig of the Month for those of you who don't already know) Then on March first the winner will go up against all the other chapters. All of naxja will vote on the top three and one of them will go on to win next month's national ROTM. So...Here are the rules.
  • Only Red Members are allowed to compete.
  • You can not have won in 2010
  • There is no limit on the number of rigs that enter, but all submissions must be put in before Feb 24th.
  • Feb 25th thru the 28th voting will take place, and the winner will go on to compete nationally.
  • March 1st a National Poll will be started containing the top rig from each Chapter.
Go ahead and post two or three good pics of your rig in this thread. You should include at least one good action shot and another good Driveway shot. Then include a good spec sheet for your modifications.
Good luck guys!!
Let me see.....
Specs on my Junk are as follows:
1996 Cherokee
Engine: 4.0HO
High Flow Cat
Magnaflow custom bent exhaust
3-Row All Metal Radiator.
Transmission: Stock AW4
T-Case: NP231
Lift:
-6.5” Superlift front coils
-3.5” leafs
-1.5” shackles
-HD Offroad Engineering Shackle Relocators
-RC Control arm drop brackets
-Fixed RE lower control arms
-Adjustable RC Upper Control Arms
-extended brake lines.
-RC HD Double sheer Adjustable Trac Bar.
Front Diff: HP D44 (stock width)
-4:10 gears (currently)
-Quick Lock Aussie style locker
-Custom DOM crossover steering
-WJ Knuckle swap
-WJ Dual Piston Calipers on Ford Explorer Sport Trac Rotors
Rear Diff: 29 Spline Chrysler 8.25 (currently, Have an 8.8 going in this weekend)
-4:10 gears
-LSD
Tires: Super Swamper Q-78 15's (measure out to be right at 36")
Wheels: 15x8 Custom beadlocks
Armor:
-Full custom exo cage
-Custom front winch bumper w/ winch (integrated into cage).
-Rock Sliders integrated into roll cage
-Custom rear bumper with swing away tire carrier.
-THOR Upper Quarter guards
-JCR Lower Quarter guards
-WORP Speed Offroad Xfer Case Skid
-WORP Speed Offroad Gas Tank Skid
-Solid Front Diff Cover
-RockCrusher Rear Diff Cover
Body:
-Bushwacker flares trimmed to clear 36’s, and integrated into Exo Cage.
Recovery:
-Hi-Lift Jack
-Fire Extinguisher
-CB Setup
-MM 9,000 lb. winch
-Full recovery kit, including first aid, snatch blocks, tree savers, food, fire starters etc....
Parts acquired but not installed yet:
-Ford 8.8 rear, with disc brakes
-Steering box ported for hydro ram
Misc. Stuff:
-Bluetooth CB radio for hands free cell phone communication.
-Pioneer CD player with Steering wheel remote.
-pioneer Speakers in all the Factory Locations
-Orion XTR 10" sub in a ported box with a 200 watt amp
I am sure there is a whole bunch of junk I am leaving out, but you get the point. LOL
1991 Briarwood
184k miles
4.0
AW4
NP242
Dynomax Catback
2" Coil Spacers
1.5" Lift Shackles
Heavy Duty replacement leaf springs (3" lift total for rear)
V8 ZJ Tie rod
RE Gen2 Quick Disconnects
8.25 with ZJ Disk brakes
OEM Swing away tire carrier
15x8 Jeep Ravines
31x10.15 BFG AT KOs
To do list:
Rebuilt 242 with HackNTap
WJ Control arms
Lift the front another inch
Brake lines
Armor
I would Like to throw my name into the hat!!!
Heres a few Specs.
'91 2Dr. XJ/AW4/D30/D44 RE 4.5" lift, Adj UCA, LCA and XD-Adj. Track bar and Bracket, Full Leaf's, RC 2" lift shackles. RC drop Brackets, 33x12.50x15 BFG MT's on 15x10 AR rims. JCR stage 2 winch bumper. Mile Marker SI12,000 ,Procomp MX-6's. Dual "A" pillar Gauges Trans Temp, Air to Fuel Ratio Gauges, Currie HD Steering, Advanced Adapter SYE and Front DS.
Ok let me clear something up. The ROTM contest allows ONLY 2 pictures of your rig. You guys are going to have to narrow it down a little.
Oh and you can ONLY vote in your chapter. No "cross voting", if you do that then ALL of your votes will be deleted.
Nice looking rigs guys...... No more than three photo's in the RRC, and once a winner is picked it will have to be narrowed down to to two photo's of the winner's rig to be put into the National Poll.
i suppose ill play for some grins!
2000 225,000 miles and saw the plastic taken off the seats at the dealership
4.0 out of 99
99 header, downpipe and flowmaster
Upgraded Wiring by 5-90
AW4
242 with SYE and front driveshaft
Suspension
RE 3.5" kit with full packs
1.5" spacers in front
RE Drop Brackets/Braces
RE Superflex Adj. Upper/Lower control arms
RE HD trac bar and bracket
RE trac bar cross brace
RE stainless Brake Lines on Rear
Chevy 1500 Brake Lines on Front
OME Long Travel Shocks
Axles
99 HP D30 with 4.56's
tru-trac
Ruff Stuff Cover with countersunk bolts and drain options
98 (im pretty sure) 29 spline 8.25 with 4.56's
auburn pro ls
ZJ disc brake swap, kj ebrake cables
Tires/Wheels
265/75 Maxxis Bighorns
16" Limited Edition Dark Grey Rubicons (only 1,000 sets made to my knowledge)
Correct Matching Spare
Armor/Recovery/Misc
Iron Scorpion Front Winch Bumper warn shackles
XRC8 Winch with Synthetic Amsteel Blue Line
JCR Sliders
CROK rear bumper with warn receiver shackle
Hi Lift, straps and all that jazz
Cobra CB
Eclipse HU/Infinity Components
4 gauge wired distribution block for all interior switches, electronics
Misc. Scratches, occasional missing flares as well as dings from running into trees and the like i think that should sum it up for as much as i can remember now
I think this thread just goes to show you that..... everyone knows white XJ's are the best!
I have no recent wheeling Pics with the 35s and stuff. I will though
Just get you some wheeling pics, taken before the 24th, and post'em up!
Its a 98 Jeep XJ-- 4.0
auto aw4 with brettm shifter
8" or so Rustys longarm suspension with full leafs rear.
36" tsl super swampers on 15x8 rockcrawler wheels with the holes
Custom rear bumper with a jcr offroad bumper front (I think), custom square tube rockrails. Steel tailight boxes (unknown manafacturer)
Dana 44 front 5.38s auburn ected, ballistic fab beefy dom steering with qa1 heims. Ruffstuff diff cover
Ford 9" rear trussed with 5.43s and a full spool.
Currently getting a full exo and eventually partial interior cage.
is that first picture still when blake owned it? Its a nice jeep man great find and sounds like your adding even more to an already great platform!
No the first picture I wheeled it a local place that really serves no challenges whatsoever but its a good test bed. Thanks Blake built a sweet Jeep!
Can I play. Im about done with my rebuild and dont have any "action" shots with the exception of running over some tires. I wont be able to get any good wheeling shots till next month (mega run)
1987 XJ 4.0l NP231
approximate 7" lift RE, RK longarm, HD shackle brackets with 1.5 shackle 105" WB, flipped xj springs 40" Goodyear MTR's/H2 wheels
Front Dana 44 (79 Ford) TnT truss with brackets, 4.88, ARB, ARB cover, Nitro 4340 shafts, CTM's, Warn lockouts, agr rock ram hydro assist
Rear Dana 60, ARB, ARB cover, 4.88, Disk Brakes, stock shafts
misc braces, tube cage (not done), relocated gas tank, Logans metal front bumper, slick rock rear qtr armor, skids
