crazyoffroader
- Seattle, WA
I have an '88 with an AW4 that seems to be having tranny problems, especialy under a load.
I pulled the dipstick to check the fluid level and found the level to be correct, but the color was something just a hint darker than new motor oil.
My question is: can I get away with changing just the fluid and filter?
Just in case the tranny fluid is not the only problem, these are my symptoms:
shifts up too rapidly, so that when going 25mph I am in OD
shifts up rather than down when pedal is floored
only shifts down manualy, or when going <15mph
torque converter locks and unlocks hard
comfort/power switch only works when it wants to
I have a good spare AW4 in the garage, but I would rather use the one in the truck if I can.
Thanks in advance for the help.
