96 Classic won't start
Squirly
Montrose CO
96 classic, 4.0 auto won't start! Has spark but no fuel! I've checked fuses, relays & put a new pump in! Tried a different computer, it was a different # but out of a 96 taxi model, no luck! It appears as though no power is being sent to the fuel pump! Any ideas?
Thanks
Troy
If you can hear the pump run for a few sec. when you turn the key on, i would bled the lines. If not I would check Pump Fuse
As suggested, confirm that the fuel pump is priming for 3-5 seconds. Have you tested the Crankshaft Position Sensor ?
Pump is not cycling! I've checked fuses & relays all good! Could the srank sensor cause the fuel pump not to get power?
Thanks
Troy
