98 Junction Block ambient temp sensor location OHC
sampil
texas
Does anybody know where in the Junction Block are the 2 pins for the ambient temperature sensor? These wires are VT/LG & BK/LB (violet/light green & black/light blue).
These are the last 2 connection I need to make to finish the instal of my OHC.
(I dont have the original harness).
Junction block C301, CAV (pin) #3 G32 20BK/LB & #4 G31 20VT/LG
edit>>>nevermind, the info I posted is for the 00-01 XJ. The junction block on the 00-01 has 10 cavitys while the 98 has only 8.
I have a pic of the 98 connector but it is difficult to make out the exact pin location of the 2 wires although you can see the correct wire colors.
Here's a pic of all 4 different types of junction blocks for the overhead console. (keep in mind that these are the chassis ends of the console wiring harness so the junction blocks on your Jeep will be the mirrored opposites)
The top is 97, next down is the 98, then the 99 and last is the 00-01.
The middle connector block is the one you want (8 pins: 3 across the top & 5 along the bottom)
Here's a side view of the 98 connector.
