Exhaust Manifold Adapter Pre 2000 to 2000+
markjrs3
Rhode Island
Hey all, there's old threads and people who had access to the adapter plate for using a pre 2000 motor in a 2000+ (0331 replacement) but I can't find any updated contact information for someone who has access to where to find them.
Can anyone point me in the right direction?
Thanks
If you buy a banks header for a 2000 model you won't need it. Just buy gasket to match the head year. A stock gasket will work. I'm assuming you have the duel cats? It will have 2 ports to match the exhaust with the two cats.
Yes, the Banks' header, for the 2000-2001 0331 head and dual mini-cats, will fit the better flowing earlier heads.
It comes with the proper gasket,eliminating a lot of problems. You still need to fab brackets for the coil rail or convert to a remotely mounted coil.
This sounds like a great idea in theory, but it's also throwing a ton of cash at the problem.
In the past it looks like people have fabbed an adapter and tossed a gasket on each side and called it a day. If I could find a used Banks somewhere for reasonable money I'd consider it
