Oil pressure gauge
mudslinger4x4
Connecticut
i have a 94 and just recently my oil pressure gauge started acting up. when i start it up it goes to 40 but then when i start to give it gas it goes up way too fast and eventually will go past 80 and hit the stop all the way to the right. i did an oil change about 100 miles ago and just rechecked the oil and there is enough. made sure all my connections were good and it still happens. i don't know if this is something i should be worried about immediately but i have also started to smell something burning after i park it. i think it's oil but there are no signs of it. this problem just happened after i removed my intake silencer, but i don't think that could have anything to do with it. anybody have any suggestions? i need to get this fixed ASAP
Did you replace the oil pressure unit by chance also?
Napa I think sells them for around $20
i didn't change anything on it. it was running fine until i took out that silencer so i'm gonna try to put it back in to see if it fixes anything.
