Old August 23rd, 2017, 11:03
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
HVAC vent control fixes
In 15 years I have found 4 issues that can screw with vent air velocity and vent outlet controls.
Two are have to do with the Vac line near the engine bay firewall near the AC and heater hose line connections to the firewall on the passenger side.
One is is dry rotted Vac tubing/hoses in that area.
Two is a missing or bad check valve on the vac line in that area that goes to the HVAC controls through the fire wall.
Check valve:
NAPA part #V14189 , 2-1015,
bar code 7 07390 75798 8
Just replace a missing one today. Huge difference :-)
Three is knocking loose the hoses and bulk connector on the HVAC controls in the dash installing say a radio.
Fourth is a bad diaphragm valve that operates the damper doors on the passenger side under the dash.
Ther are other damper door controls under the dash near the drivers right knee, that cause issues too. Have not had one there yet.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
1988 Xj: HVAC Control Provides only Defrost RAVC1 OEM Tech Discussion 6 September 10th, 2017 15:24
HVAC control swap Kego814 Modified Tech Discussion 18 June 29th, 2017 13:23
HVAC vent to defrost uphill, cruise works Desert4x4 OEM Tech Discussion 32 October 7th, 2014 07:40
HVAC control panel compatibility Monster Mopar OEM Tech Discussion 11 December 16th, 2011 19:04
'91 HVAC control door ehall OEM Tech Discussion 2 July 29th, 2009 18:51
