joshv98xj
- Bozeman, MT
Just finished up the ZJ disc swap into my 98 and D44, brakes are a little squishy, so I'm gonna do the prop valve. No the calipers are not on upside down. No there is no air in the lines. I bled til I used up most of a 32 oz bottle of fluid.
I read somewhere on here that you can just swap out the innerds of the prop valve instead of the whole thing. Which end am I taking apart? I disassembled the ZJ valve today, but couldn't get everything out. One end had a cap, and underneath that a spring and plunger thing. The other end had a cap, under that was a plunger sort of thing with a slot in the end of it, but I couldn't get that out. What do I need to pull out? Any pics? Thanks-
