Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old July 18th, 2017, 12:12
SByota SByota is offline
Re: New guy build-The Family Truckster
Yes, I used a non contact IR temp gun.
As far as the double shear:
There are plenty of people running the WJ knuckle swap with rod ends in single shear. Even the Petty Cash KOH racer runs WJ knuckles with single shear rod ends. That car gets used harder than my Jeep ever will. As far as I know, they have never broken a knuckle at the steering. Even when the knuckle was broken in half with an impact with another car, the steering survived.
The adding of the double shear will only strengthen what's already there. The addition of the plating will greatly reduce the stress on the knuckle by not allowing the bolt to flex at all. In my view, this will prevent the big 3/4" bolt from turning the hole in the knuckle into an oval. I have no doubt that if I break the knuckle, something very dramatic happened and lots more will be broken too.
I enjoy this type of idea sharing and feedback on my work. One can never stop learning and having an open mind leads to learning.
Old July 18th, 2017, 12:39
burntkat burntkat is online now
NAXJA Member #1145
Completely agree with your thoughts on the matter.
I am curious why you didn't go with TREs? Hiems simply don't last as long as TREs from what I've heard. I haven't run them, myself.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Next: finish front, build rear bumpers, Dana 44's front and rear.
-94 ZJ: Budget boost, 31's. The wife's mall crawler. She's gotten inchitis over my S10 though...
-97 XJ: Son's DD. Mild mods for the new driver.
Old July 18th, 2017, 14:12
I chose rod ends for a few reasons. I don't have the correct reamer for the TREs. This a go fast kind of toy and I wanted strength over longevity. This Jeep will see lots of desert racing as a chase/support/spectator vehicle. Should I break a steering joint, it will be way easier to find a rod end than a specific TRE.
Old July 18th, 2017, 14:32
NAXJA Member #1145
Ah, built to purpose. I like it! It's also a lot easaier to carry one or two spares than 6.
Old July 29th, 2017, 15:05
Making more progress on the front end. WJ knuckles all finished, lower links, tie rod, and drag link and cut to length and tacked up. I used PVC pipe to determine the angle of the upper links. Then I cut my tubing on the bandsaw, and used my homemade fixture table to hold it in place.
Next garage session I will tack together the upper arms and make the panhard bar and cycle it. Then I'm sure I will have to change something. There is so much going on with this "5 link" suspension.
As always, everyones input/criticism is welcomed.
Old July 29th, 2017, 15:06
Old July 29th, 2017, 15:12
Old July 30th, 2017, 09:27
NAXJA Member #1145
I'm liking the mini layout table. Where did you get the idea?
Old July 30th, 2017, 15:19
I really wanted one of the tab and slot tables, but the top is pretty thin and the fully perforated surface makes for a pretty lousy general work bench. My garage is a do all kind of place and I have a pretty big/study work table with a stainless top and big cast iron legs.
I built the fixture table as a compromise. It's big enough to clamp 99% of what I build but small enough that I can stash it away. It's all 3/8" cold rolled steel TIG welded together, so its stout. I love it, makes getting parts just in the right position before welding and actually holding them there.
Old August 11th, 2017, 15:22
Mocking up the WJ brakes and new unit bearings. This is at full bump with a 35" tall tire.
Old August 12th, 2017, 23:24
Getting the front end one step closer. Setting up the lower spring mounts, bumpstops and track bar/track bar mounts. It's getting there slowly.
Old August 13th, 2017, 15:21
ftwelder's Avatar
ftwelder ftwelder is offline
Great fab and layout work!
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old August 13th, 2017, 19:31
Thanks!
Had the apprentice in the shop today.
Old August 14th, 2017, 06:24
NAXJA Member #1145
Coming along great- and you win at Dadding.
Are those the Ruffstuff framerail reinforcements? I'm looking at installing them on my son's 97, even though it won't see any hardcore wheeling anytime soon. It's strictly providing a surface to build off of, and to prevent damage to the unibody from twisting. I'll also be curing the body rot issue by cutting out the rockers and welding in some 2X6 tubing, which will be tied into the framerail boxes as well.
Old August 14th, 2017, 13:02
Yes, I used the Ruff Stuff reinforcement plates/panels. Great product and fits the frame great. If you do the front and main frame together, you will have to do fitting/cutting to make them work together.
Welding on the dirty nasty galvanized XJ frame rail is terrible. I cleaned to bare metal and sanded to a smooth finish. I still got porosity in some of the beads. I'll grind them out and redo, but I'm looking forward to never welding on galvanized metal again.
Your plan sounds great. The 2x6 is a perfect fit. I considered doing a replacement rocker like that, but mine won't see a ton of rocks.
Family centered overland build overxjland Adventure Forum 5 February 25th, 2016 10:41
Tom95YJ's Family Wheeler Build ... Tom95YJ Modified Tech Discussion 80 March 2nd, 2013 22:25
Family wheeler build XJdriver Arizona Chapter 23 December 24th, 2012 11:16
The Family Build CarolinaCrawler South East Chapter 18 October 22nd, 2012 09:19
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
