I have started my front bumper and can't decide on how to go from here. I was making a winch mount on top but the bumper will stick out approx. 8" from the front crossmember thingy(technical term). My other thought is keep good approach angle and just make two reciever hitches in the front of the bumper about 15" apart and make a winch plate similar to the warn plate where it slides in the hitch but have two tubes that attach at 20" apart for more stability and strength. also going to do the same to the rear but with 3 hitches so I can tow with the middle one. What are your opinions on winches mounted on the front only on top of the bumper and the removable plate which would you go with. Thanks I will give updates.
DIG IT!!!
DIG IT!!!
