Acceleration on the highway will suck. Your speedo will be off by about 12-15%. I'd forget about towing anything.Is running 32" tires possible with stock gears? Will the motor lag too much? Do's and don'ts type of things. What is the biggest tire acceptable with stock gears. This is my daily driver. Please help. I did a search and came up with nothing.
Yeah, you do run the risk of heating your transmission up a lot more. You should probably install a tranny cooler for crawling anyways, they're cheap at the junkyard.And if you have an auto,your really hurting it!
Crawling isnt a problem due to the extra gear reduction,its on the road that will kill it!You should probably install a tranny cooler for crawling anyways, they're cheap at the junkyard.
I know. But sitting around at low speeds even with the right axle ratio is going to result in you wanting a tranny cooler anyways, that's what I was getting at.Crawling isnt a problem due to the extra gear reduction,its on the road that will kill it!
Odd, mine is a bit gutless at some speeds but it's not really too too bad. I find that getting from 50-65mph is pretty bad, but once I'm at 65-80 or so, I can just cruise. It'll easily do 90 into a headwind but not uphill... I try to avoid needing to go that fast, so I usually cruise around 75 or 80 (speed of traffic in these parts) without any real issue. I get 14mpg or so uncorrected, so 16 or so corrected - I was getting high 17 to low 18 range before. I'm hoping I recover at least some of this when I get my new axles with 4.10s in, though the larger tires will obviously weigh more and have more rolling resistance.im on 33's on a stock gears/rear end it blows on the highway. I have the biggest dead spot, aka the heep doesnt want to go anywhere without rodding the piss outta it from ~40 to ~55 (uncorrected speedo). Mileage blows too. im getting ~11-13mpg. Lets just say i like to get passed by delivery trucks, prius', and grandma's...
But it still had enough ball/gearing to yank my friends f250 out of the ditch the other night.
Odd, mine is a bit gutless at some speeds but it's not really too too bad. I find that getting from 50-65mph is pretty bad, but once I'm at 65-80 or so, I can just cruise. It'll easily do 90 into a headwind but not uphill .
Mine did fairly well with 32s, you'll loose a bit of power but it's not the end of the world. If you live in a hilly area, though it's going to be a royal pain. I have an auto with no aux cooler and never burned up the fluid... That AW4 is better than some people give it credit for. High speed flat highway stuff is pretty good, gas mileage-wise. But getting up to speed and maintaining it in the hills is the hard part.
