Alternator mounting brackets- years different?
DPG
Kansas
Hey gang,
I was swapping my alternator yesterday and when I got it apart, I found that BOTH of my mounting brackets are broken!!!
Apparently, the guys who swapped the '99 motor into my 2000 XJ left a couple of bolts out and the subsequent bouncing around over time messed them up.
A local salvage has them, but they are off of a '96 model.
Anyone know if these are all the same or if they change with different years...?
Thanks!
Dirk
just checked my parts catalogs. Both use the exact same mounting brackets.
Sounds great. I found part#'s on mine-
Cast aluminum bracket is #53006868
steel front bracket is #53006869.
Assuming that's what you're showing...?
don't remember. Closed them. Bottom line - they are the same, you'll be fine
