Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-27-2010
green95xj green95xj is offline
Stalls on fast left turns
98 xj aw4 231 taking a left turn onto a street if you have to do it fast the jeep will first Act like it's running out of gas then die. This only happens on left turns. It does happen on left turns in the road if it's sharp enough. Any ideas I need to get this fixed. Thanks
Old 07-27-2010
Floydargue Floydargue is offline
I have not Confirmed, or I used a BAD email Addy
Re: Stalls on fast left turns
It always does this, or only when you are low on gas? This will always happen when you are low on gas. Mine does it on hard lefts below about 3/8ths of a tank. If it does it all the time, I am not sure what the issue would be. Maybe a weak or dying pump?
Old 07-27-2010
the_weirdo's Avatar
the_weirdo the_weirdo is online now
My 98 would do this when the tank was less than a quarter full. When above a quarter full it did not have the problem. Turned out to be a clogged up fuel filter. Unfortunately the fuel filters are in the tank so you need to drop the tank to replace them.
Old 07-27-2010
muddypunk's Avatar
muddypunk muddypunk is offline
I just put a o2 sensor on 94 zj and unhooked the battery to get the code to go away and no if I stop hard it dies and I have no clue why .If I slowly stop no problem hard stop it dies can any one help me
Old 07-27-2010
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
Couple things I would check--engine and trans mounts, including the bolts that hold the mount-to-engine brackets on. Then look/feel along the crank sensor harness to see if it has any frayed or burned spots. Also, check the crank sensor bolts as well as the bellhousing to engine bolts for tightness.
Don't drive an XJ with less than 1/4 tank of fuel. You should be keeping at least 1/2 tank full, just in case of a Zombie uprising!
Post up what you find.
Good luck.
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 07-29-2010
phxmark phxmark is offline
My 2000 does this when the fuel tank is less than 3/8 full.
Is there any way to remedy this besides a fill up when at 1/4 tank??
Obviously there aren't any baffles in the tank.
Old 4 Weeks Ago
joe_peters's Avatar
Paying it forward
There actually is a large "bowl" inside the tank that is supposed to help with the problem.
EDIT: not sure if the 97+ plastic tanks have this feature.
Old 4 Weeks Ago
I just put the motor in trans and motor mounts are good. No burnt or chafed wires I can see. Filled the tank up and still does it. I was just in my 97 xj gas tank changeing the pump so I know there is no baffle in the tank. Any other ideas I rolled the 97 now I need this running right to be my dd. Thanks
Old 4 Weeks Ago
joe_peters's Avatar
Paying it forward
How about if you go into a parking lot--empty--and make hard left circles?
You can hook up a fuel pressure gauge and duct tape it to the windshield, make the left turns and see if the fuel pressure is dropping out.
Trying to find out if it is fuel supply or ignition cutting out is going to be hard.
If you keep the rpms up will it keep going? Could it be a low idle/PS pump problem?
Old 4 Weeks Ago
Don't think it's a low idle issue because it will die when I'm on the gas. I can't seem to find a fuel presure gauge with a long enough hose to be able to drive and read it. Thanks for the ideas.
Old 4 Weeks Ago
Talyn's Avatar
Talyn Talyn is offline
Blargh
Don't turn left.
Possible faulty fuel pump, bad wire connection, lose ground, faulty fuel pump relay.
4.6L Stroker
www.jeepstrokers.com
Old 4 Weeks Ago
xjbubba xjbubba is offline
NAXJA Member # 1524
Like "joe" says, you need to isolate a fuel delivery problem from an ignition issue. Doing as he suggested would help to give you a starting point.
Loosing fuel pressure, as indicated using a fuel pressure gauge, during an "event" would help you to narrow the issue down to fuel delivery or "other". It would appear that a loose connection (electrical or mechanical) is aided and abetted by centrifugal force. My bet is loose electrical wire/component.
'88 XJ, Chevy 5.7L, Edelbrock MPFI, D44's, 4.56's, ARB's, NV4500, Atlas, 6" custom long-arm lift, 4wheel discs, 33x12.5-15's.
Death Wobble 45-55mph, on left turns blairboyd Modified Tech Discussion 12 08-29-2007 23:15
97 XJ 4L stalls when I turn left ??? XJTony OEM Tech Discussion 5 12-31-2006 21:56
Front end vibes during left turns only? RyleyF Modified Tech Discussion 5 11-03-2005 16:50
turns sharper to the left than to the right? afd516 OEM Tech Discussion 7 04-23-2005 13:18
sputters + stalls @ 1/4 tank on left turns winterparker2b OEM Tech Discussion 8 12-30-2004 16:24
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
