Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 07-27-2010
brianglawson's Avatar
brianglawson brianglawson is offline
Question Where to get Closed Cell Foam Sheets for Carpet???
SOOOOO... I got the inside of my XJ soaked 3 times in one week running doorless and not having a spare minute to get them back on. I've been driving it around for a few weeks with no carpet since then, but only to go to the river and haul my kayaks. It is WAY too hot in there for my little girl or dog for that matter, even with the AC on.
I am getting a new piece of carpet out of a wrecked XJ, however i would like to tear all the Jute off and replace it with CLosed Cell Microfoam sheets.
I imagine that i will glue them to the back of the carpet in relatively the same pattern as the Jute.
Question is where can I order this stuff??
I want something that wont absorb water, but is flexible enough to bend around the tunnels and such.
Thanks
Brian
P.s. what about this stuff? http://www.closedcellfoams.com/neoprene.html
Old 07-27-2010
Re: Where to get Closed Cell Foam Sheets for Carpet???
or would this be better? http://www.closedcellfoams.com/gymnasticrubber.html
Old 07-27-2010
FYI for those who don't know and are curious, Closed Cell Foam doesn't absorb water. So, if your Jeeper gets wet inside the carpet could dry much better without having the Jute to suck up the water and the closed cell foam will still provide good insulation. My jute hasn't dried after 2 weeks of being uninstalled even!!!!!
Old 07-27-2010
ehall's Avatar
ehall ehall is offline
I bought a bunch from a local upholstery shop
Old 07-27-2010
oh? good call havn't thought about that!
Old 07-27-2010
Mesh's Avatar
Mesh Mesh is offline
NAXJA Forum Supporter
I used Ensolite to replace my jute padding. Ordered from www.RAAMAudio.com they also sell a peal and stick version.
Old 07-27-2010
John D's Avatar
John D John D is online now
NAXJA Member # 788
And you are happy with it?
Was it worth the $ and effort?
Would you do it again?
Old 07-27-2010
Mesh's Avatar
I used it on top of sound dampening material so the application would be a little different. Working on a hard surface it was easy to apply. I used spray glue let it tack up then stretched the foam a little. Applied some pressure and it stuck to every curve or crease. I’m happy with the result but it was also a lot of work. If I ever did it again I would spray the interior with LizardSkin then throw down some Ensolite on the larger surfaces no glue and call it a day.
Here’s a picture of what it looks like under my carpet.
Old 07-28-2010
kastein's Avatar
kastein kastein is online now
wheelin' on 10 42s
I would suggest applying bedliner or similar heavy duty paint to the floorboards before installing the foam - water will still wick between the foam and the floor, and this way it will not cause rust.
DD "dirty POS": 91 MJ, 4.0+AW4, D30/D35, Northeastern Speed Holes; future: C8.25, NP231
tetanus taco: 96 XJ, 4.0+AW4+NP231, D30/C8.25, 3.5", 33x11.5 ATs, OBA, OHC, Northeastern Speed Holes, flintstones floor option; future: more floorboards
Prototyping/testing rig: 98 XJ, 4.0+AW4+NP231, D30/C8.25; future: SYE, 8.8, 4.10s, 33s, bumpers, 0-3" lift
1958/1990 Jeep M54A2, multifuel LDS465, Spicer 6352 5-speed trans, Rockwell T138 transfer case, 5 ton Rockwell axles, 42s, future: 46" Michelin XMLs
Old 07-28-2010
yossarian19's Avatar
yossarian19 yossarian19 is offline
x2
If you are already in there making improvements, it would be a crime to overlook bedliner to rust proof your XJ. Since you are putting carpet over it, you can probably ignore the gooey foil patches & just lightly sand, wash & bedline the interior.
Then foam & carpet, or sound dampener foam & carpet, or...
Old 07-28-2010
joe_peters's Avatar
joe_peters joe_peters is online now
Paying it forward
My only concern would be reaction to heat--over the CAT and exhaust.
is just like Soylent Green, its the people that make it so good!! 90 2-Dr Sport-I6 4.0 w/zj HD fan clutch, Ford 19# injectors-AX15-NP231 w/1" drop & AA bracket conversion-D30 CAD w/Aussie Locker & D35; 3.73 gears-4.5" lift front & 5.5" lift rear-Bridgestone 31x10.5x15 AT-K&N cone Rusty's intake tube, tb spacer, steering conversion-Hurst shifter-5-90's cable upgrade-Terraflex disconnects-adjustable track bar-drop pitman arm.
Old 07-29-2010
I took out my carpet a little over a year ago. Only seems to get hot on longer drives and then primarily in the trans tunnel, mostly up front where the drivers / passenger's feet are. I put closed cell foam down in the cargo area and haven't noticed any funny smells from there.
If I were going to foam the trans tunnel, I'd shoot it when it was good and hot with an IR thermometer and find a foam that could take that temperature. Alternatively, insulate the underside of the trans tunnel.
You could even look into heat reflective foil to glue to the underside of the foam, though we are now getting into fancy-pants tech. A clear violation of the KISS principle.
Old 4 Weeks Ago
austinaubinoe's Avatar
austinaubinoe austinaubinoe is offline
I was just at sears and they are selling those foam shop floor tiles that fit together like a puzzle, except these are 2'x2'. There $19 for a 6 pack and one side has a grey carpeted surface.
After I monstaline my cherokee next month, I may by some to quiet the cargo area.
2000 FERN GREEN Cherokee Sport<>Rebuilt 97 4.0L, 35 spline HPD60 W/ Lock-Right out of a '78 F-350, Warn locking Hubs, Crane diff cover, Crane Hi-steer, RK 3 Link, Rustys 8" coils, Tom Woods Shaft, 35 spline D60 W/ ARB out of a '99 E-350, Rusty's 6.5" leaf packs, RK 1.5" shackles, Tom woods Shaft, AA SYE, 35x12.5 SSR Super Swampers, 17x9 Cragers
Free Parts: AC condenser, black ac cylinder thingy, 3 stock grab handles, TJ coils, Tj rear sway,
Old 4 Weeks Ago
Yup, same tiles I bought. Trimmed & put down in the cargo area. Quieted down the cargo area nicely. Haven't endeavored to try and get the passenger area yet.
I bet you could put the same tiles down on the floor boards and under the seats, leave the trans tunnel alone, quiet it down some more.
Old 4 Weeks Ago
I ended up using Foil insulation from Lowes. It was $30 for the roll and It's awesome!! It's foil on both sides with air pockets in between. Used about 3 layers of it because it is pretty thin, but seems to work great!!!. Carpet is cool to the touch!!!
factory build sheets GrimmJeeper Non-Tech / Off Topic 42 06-17-2010 08:32
Where to get .5" steel sheets? Hubbazoot Modified Tech Discussion 11 12-24-2008 23:59
---> Where to order Delrin Sheets? uncc civilengineer Modified Tech Discussion 3 10-24-2007 12:52
Where to buy big steel channels / sheets etc. Mdub Arizona Chapter 5 06-20-2007 21:12
XJ build sheets..? xjwoody OEM Tech Discussion 36 11-20-2003 12:33
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
