Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Frequently Asked Questions and Writeups
Frequently Asked Questions and Writeups FAQ topics on common and frequently posted issues. No posting or replies allowed.
Old July 1st, 2005, 16:33
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
What should I bring to the trail?
Tools:
Wrenches, sockets, and ratchets
Screwdrivers
Goggles/helmet for welding
CO2 tank
Power inverter
Air/power tools (if available)
Hi-lift jack
Bottle/scissor jack
Pliers/wire cutters
Lug wrench
Ratchet straps
Bungee cords
Hacksaw
Pry bar
Big C clamp
3 Lb. sledge
Pickle fork
Tire gauge
Valve stem core remover
Snap ring pliers
Telescopic magnet
Haynes Jeep repair manual
Spare parts:
CPS (crank position sensor)
Coil
Fuel Pump
Power steering hose (high pressure side)
Radiator hoses
Ball Joints
Leaf spring center pin
Shackles and bolts
U-joints for driveshaft and axle shaft
Clutch line (if applicable)
Ballast resistor
Quick connect fuel line fittings
Spare tire
Front and rear axle shaft assemblies
Hubs (if applicable)
Rear drive shaft
D30/D44 pinion yoke
U-bolt style yoke straps
Tubing to sleeve tie rod/drag link
Cap and rotor
A couple spark plugs
Fuel injector
Stuff to make spark plug wires
Hiems/tie rod ends (if applicable)
Motor mount
Serpentine belt
Plugs/caps for brake lines and brake parts
Large selection of spare bolts, nuts, washers, and screws
Consumables:
5 gallons gasoline
4 quarts engine oil
2 quarts diff fluid
2 quarts t-case fluid
2 gallons coolant mix
1 quart power steering fluid
2 small bottles of clutch/brake fluid
Misc. hoses (fuel, vacuum, heater, etc)
Valve stems
RTV Silicone
Can of Fix-A-Flat
Tire plug kit
Gas tank repair kit
Welding rod
Assorted hose clamps
Tub of grease
WD40
Brake cleaner
Hand cleaner
Spill-Tec absorbent mats
Paper towels
Epoxy
Zip ties
Bailing wire
Cotter pins
Snap rings
Duct tape
Electrical tape
Fuses and relays
Wire and misc connectors
Recovery/safety:
Winch
Tow straps
D-ring shackles
Tree saver
Snatch block
Rope/chain
Shovel
Hatchet/axe
Gloves
First aid kit (w/ Tylenol)
2 fire extinguishers
CB radio
Jumper cables
Flash light
Blanket
Toilet Paper
Cell phone
Matches
Heavy duty trash bags
Food and water
Change of clothes (especially shoes and sox)
so what are you bring MDXJ NAC Fest 2006 1 June 1st, 2006 19:33
So what did Santa bring you? crazy4mopar Sierra Chapter 16 December 28th, 2005 10:42
Somebody please bring... woody 2004 NAC Fest 0 June 10th, 2004 05:56
What to bring? (firewood...ect.) ryurabbit 2003 20th Anniversary Celebration! Moab, Utah 11 September 25th, 2003 08:20
