Old November 20th, 2017, 08:28
Heavyopp Heavyopp is offline
Re: Transmission Cooler Line
Looks like summit racing part # SUM-2206678 for the top port adapter
the bottom one I found easier to use the 3/8th compression adapter over a threaded adapter -- just not much space to make the turn
I also used the BM 70273 cooler -- I like those heavy 1/2 NPT connections
Old November 20th, 2017, 17:49
ehall's Avatar
ehall ehall is offline
No such part number
my '91 beater rebuild
Old November 20th, 2017, 21:25
Originally Posted by ehall View Post
No such part number
Sorry was reading it from the bag in the picture -- Just checked my account at summit -- looks like saw an 8 instead of a B
The part number is 220667B
https://www.summitracing.com/parts/sum-220667b
Old December 1st, 2017, 11:01
ehall's Avatar
Okay I have been struggling to find an AN-6 adapter for the upper port for a long time, so have a lot of other people.
I found a cooler line and fitting at the junkyard and pulled it to adapt before I saw your Summit fitting. As you can see the Summit fitting is the correct thread in comparison to that fitting. If you have a radiator with a removable adapter then it should work fine
However the '01 Mopar HD radiator that I have does not have the adapter fitting. Instead the fitting is brazed to the internal tube, and then secured to the side tank with another nut. The fitting is not removable.
In order for me to do an AN-6 fitting, I need a female 5/8-18 invererted flare to male AN-6 adapter, no such creature exists. At this point I don't even think its necessary, but now its like my personal holy grail and I want to try to find one.
Thanks for the link though
Transmission Cooler Line abzrocka OEM Tech Discussion 3 March 16th, 2011 17:21
transmission cooler line? rufus_1111 OEM Tech Discussion 26 November 14th, 2008 19:02
Need lower transmission cooler line smcdonaldaz Arizona Chapter 3 September 5th, 2008 23:21
94 XJ AW4 Transmission Cooler Line Matt_West OEM Tech Discussion 14 March 19th, 2007 20:29
transmission cooler line help freebird12345687 OEM Tech Discussion 1 May 21st, 2005 20:52
