Old March 4th, 2013, 14:01
troy5118 troy5118 is offline
Re: Trussed 8.8 build with traction bar
Pics reattached.
Old March 4th, 2013, 14:28
jeepfreak1020 jeepfreak1020 is offline
Did you set the pinion when you welded the springs on? How did you know what angle to weld them on at?
How do you like the traction bar so far? Im thinking I want to build one for my 9 inch
Old March 4th, 2013, 14:59
I put it all together, set the drive line angle, tacked it then pulled it back apart to weld. Traction bar has been great so far. I had bent some leafs before which lead to adding it. It definitely helps the rear plant, only nag is it adds some noise but its a Jeep.. lol
Old November 21st, 2017, 07:26
Reattaching pictures.
Jeep Rear (8) by Troy Henderson, on Flickr
Jeep Rear (9) by Troy Henderson, on Flickr
Jeep Rear (22) by Troy Henderson, on Flickr
Jeep Rear (1) by Troy Henderson, on Flickr
Jeep Rear (2) by Troy Henderson, on Flickr
Jeep Rear (16) by Troy Henderson, on Flickr
Jeep Rear (15) by Troy Henderson, on Flickr
Jeep Rear (3) by Troy Henderson, on Flickr
Jeep Rear (14) by Troy Henderson, on Flickr
Jeep Rear (11) by Troy Henderson, on Flickr
Jeep Rear (12) by Troy Henderson, on Flickr
Old November 21st, 2017, 09:30
gordonganders gordonganders is offline
Thanks for reposting pics.
Old November 21st, 2017, 12:03
burntkat burntkat is offline
NAXJA Member #1145
Great work, and thanks for reattaching the pics.
Are those Treadwright tires? I love mine- I'm on my 6th set between 4 vehicles.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old November 22nd, 2017, 06:40
Yes they are, I've replaced them since then with the newer bead to bead versions and they're great.
Old November 22nd, 2017, 07:20
NAXJA Member #1145
Concur. My only complaint is that they don't seem to keep much on hand. Every time I need tires, it's a couple months of waiting.
I used that as a great excuse to buy another set of wheels... I have a spare set of 33s and a spare set of 31s. Since I have the wife and kid's jeeps on 31s, they're covered. I need to wear out the 33s and go to 35s and Dana 44s for my XJ so it's common with my S10.
D30 Trussed?? tj'sxj Modified Tech Discussion 3 February 2nd, 2012 19:43
Trussed D44 for sale krelja NAC Classifieds 10 September 28th, 2009 12:00
phew....almost got the turdy trussed Skullver SoCal Chapter 31 January 9th, 2009 18:33
Rear traction bar info/ build questions Gravesdiggerxj Modified Tech Discussion 5 October 6th, 2008 11:14
