Old November 20th, 2017, 00:10
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: Projext "V8 XJ" Build
I kind of wish I went with mild steel...for some reason my dumb ass decided to go with 304 stainless.
(Not knowing is need a different type of welding gas)
Old November 20th, 2017, 00:13
PhotoJared's Avatar
For the record I migh end up returning it (all purchased on Amazon)
Old November 20th, 2017, 00:34
indian's Avatar
indian indian is offline
I think that is better solution. I ended up with painting all the exhaust with heat resistant black spray and it works great.
LS1 intake 01 is 100% already the LS6 style. I know it because I have corvette (non Z06) 01 with this intake from factory
LS6 on the left, LS1 right...
Old November 20th, 2017, 00:45
PhotoJared's Avatar
I'm in the desert so it's not like we get much rain to warrant buying stainless
Old November 21st, 2017, 10:09
burntkat burntkat is offline
NAXJA Member #1145
I was kind of wondering why on earth you were trying to learn on stainless.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old November 21st, 2017, 10:42
PhotoJared's Avatar
Because stainless = more expensive
More expensive = better
Im probably going to keep the stainless collector and the muffler.
Old November 21st, 2017, 10:45
NAXJA Member #1145
I live in the humid Southeast. I don't have much of a problem with exhaust rusting out, to be honest. I just use aluminized steel from the parts store. Sure, it's not a mandrel bend, but it works.
Old November 21st, 2017, 10:46
NAXJA Member #1145
Stainless is also harder to learn to weld on, and honestly it's not like you're building a space shuttle here.
Old November 21st, 2017, 13:24
PhotoJared's Avatar
That's what I've been reading. Just need to get with Amazon to return. I'll probably do it this weekend.
Found a deal for a LS6 intake manifold for $320
I'm going to switch out the aluminum manifold. The LS6 manifold is going to allow my throttle body to be mounted a little further back which is going to be very helpful (i need the room)
Old December 6th, 2017, 13:22
PhotoJared's Avatar
So I re-ordered all of the exhaust tubing in mild steel. I kept the stainless collector, muffler, and v-band clamps.
I added a heat shield to the fuel line coming up near the firewall. I also flipped the fuel rail which allows me to run the fuel line up the back of the firewall over the transmission. It also gives a little more room between it and the exhaust.
Replaced the LS6 IM gaskets
Ready to go:
Installed. I'm just going to use the stock fuel rail and LS6 injectors. It will run, but i'll need to send the ECU back in for tuning. I also need to order some injector wiring adapters.
Old December 6th, 2017, 14:41
NAXJA Member #1145
Where did you source the v-band clamps? I'm looking into converting my setup to them as well when I build my next exhaust (which has become a much higher priority now that I found I have half a muffler in my XJ).
I am rehabbing my old 90, and I want to get away from the band clamps and 3-hole flanges I used there. One thing I should point out in case you haven't come across this- when welding the clamps (any clamp but apparently the v-bands especially like to walk on you), have them mated up when you are welding. Of course, vary your welding as well- weld a little here, then a little on the other side, then let it cool. Come back and connect the dots till she's sealed up.
This will give you the best shot at maintaining a sealed flange when you final assemble everything. If you just weld the v-band halves onto the pipes and then try to joint them up you will quite likely find they have deformed to the extent they no longer will seal. There's also something called a Marmon flange .. which I just happily found on Amazon!
https://www.amazon.com/42315-L-2-5-M...+marmon+flange
I haven't used these yet, but they are supposed to be MUCH more forgiving with welding, and they actually seal on a fiber gasket as opposed to a machined surface. I wouldn't buy them there, though. $24 shipping, and it isn't even a complete assembly. I'll try to find a much better source I saw a few months ago...
Old December 6th, 2017, 17:40
PhotoJared's Avatar
I got the vbands on Amazon.
Thanks for the welding tip
Old December 7th, 2017, 09:33
indian's Avatar
you definetely want to weld the exhaust on the car preinstaled. don't ask how I know it
BTW, nice progress. In few weeks we will hear it I hope
Old January 5th, 2018, 02:06
PhotoJared's Avatar
Welder is all setup. Fab coming soon.
I've also run into a small road block. Got the intake all installed and got the correct injector adapters installed.
The Jeep wont start now. I hadn't started it in a while but it did run and they only thing that changed was the intake. Unfortunately the computer isnt spitting out any codes either.
Could the mismatched injectors in the tune cause it not to start?
I’m also thinking of starting this swap process with a new shell. I’d like to use a <‘93, with manual windows and locks. Using an older Jeep would allow me to register it as a classic and not worry about SMOG. My Jeep also has a registration restriction under my name. (Long story is that I canceled insurance and never turned in the plates so according to the dmv I was driving without insurance. $1200 fine and need to carry special insurance.). I can get around this by registering under a different name or getting a new Jeep.
Old January 5th, 2018, 08:58
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
When you say it wont start, does your starter kick it, does the motor try and turn over, or is there no noise?
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 275 February 5th, 2018 15:59
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
