Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Liberty KJ and KK (2002 - 2012)
Jeep Liberty KJ and KK (2002 - 2012) Technical forum for all Jeep Liberty (also known as Cherokee in non-US markets) vehicles.
Old May 6th, 2017, 10:33
cushdaddy cushdaddy is offline
Re: KJ question sorry.
Well, I figured it out. The key on the crank that drives the timing gear failed. There was about 10 degrees of rotation on the gear. That key design is stupid. There is just one little tab that engages the gear and it broke. It looks like the key is hardened. Case hardened possibly. I'm going to check it at work Monday. Nobody local has the key so the dealership won't have them till Tuesday. This makes more sense to me than 4 bad sensors. I'll update this when I get it back together. Only question is should I replace the gear?
Old May 7th, 2017, 08:16
trippled trippled is offline
If the gear shows any damage or is questionable in any way then yes.
Old June 6th, 2017, 10:00
burntkat burntkat is offline
NAXJA Member #1145
I have no experience with that engine-0 but it sounds like a woodruff key. This has been used to hold crank pulleys on engines with no problems for years such as the SBC crank pulley. Works just fine.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old November 17th, 2017, 11:18
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Old thread, but, I think he meant Timing Gear.
The most common time you see this failure is a failure of the cam bearings.
With the advent of using aluminum heads and cams running in the head, oil starvation can cause the aluminum in the head to seize to the cam; which breaks the key.
The Damper is also held by a key, and a huge bolt. I've not worked on an engine that wasn't this way.
Wheel Hub question/limp, poor handling question - been researching fishinpolejoe OEM Tech Discussion 3 December 5th, 2016 20:03
Brake Upgrade Question (with Transfer Case Drop BONUS Question) NateEnos Modified Tech Discussion 9 April 13th, 2011 15:41
Fuel System question, Electric Fan Question POSJ OEM Tech Discussion 11 January 26th, 2011 11:18
Super quick question before I head out the door to the Junkyard. 99+ intake Question. Plays For Jeeps Jeep Street and Performance 26 October 13th, 2008 07:25
98xj 4.0L high idle question code question rapom OEM Tech Discussion 4 June 27th, 2005 17:18
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
