Old October 26th, 2017, 17:36
spidermikey88's Avatar
spidermikey88 spidermikey88 is offline
Re: Booster Upgrade
Originally Posted by muddypunk View Post
What did you do about the prop valve?
Sent from my XT1609 using Tapatalk
I kept the original prop valve and then took the brake lines from the WJ master cylinder and had the fittings replaced on the prop valve side. I still have drum breaks in the rear so I didn't want to use the WJ's valve. I can take some pics tonight if you want to see any it.
Sent from my Pixel using Tapatalk
Old October 26th, 2017, 17:37
muddypunk muddypunk is offline
TOOL
Re: Booster Upgrade
That would be awesome I need to figure out what to do on my MJ.
Old October 26th, 2017, 21:51
Re: Booster Upgrade
First I had to bend the pinch seam at the firewall up a little so it could fit the larger booster
Then I took the brake lines from the WJ master cylinder and had the fittings going to the proportion valve redone so they would fit my old valve.
The hardest part for me was the brake light switch though. I ground a little too much off the end of the wj pedal rod and that made the brake lights only come on when the pedal was about 70% of the way down (mines an 87 and I think the switch was changed in 90-91 to one that would have made this much easier). A lot of people say to grab the whole pedal assemboly from the WJ and swap that in too - which is what I will do next time. I ended up having to make a bracket that held the switch at the right angle and distance from the pedal arm.
I paid about $35 for the booster, master cylinder and the brake lines from pick and pull and $10 to have the fittings replaced at a local shop. Overall, I'd say it's worth it and i plan to do it again.
Old October 26th, 2017, 22:20
TOOL
Booster Upgrade
Sweet I have a new booster for my grand that was totaled in December. Thank you I'll be sure to grab the pedal and light assembly.
Old October 30th, 2017, 16:16
XJ firetruck XJ firetruck is offline
Re: Booster Upgrade
mgracer, have you been able to get time to complete
the swap?
Booster upgrade ! PMGaming101 Modified Tech Discussion 10 October 13th, 2014 06:16
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 10:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 21:47
WJ brake/booster upgrade,.. bxj Modified Tech Discussion 0 August 25th, 2006 22:11
Upgrade to 95 booster,M/C redwagon Modified Tech Discussion 8 September 17th, 2003 17:50
