Old October 25th, 2017, 07:29
Mirage mobile Mirage mobile is offline
Rear Leaf Downtravel / Do I need new shocks?
Hey guys,
I just added JKS shackles and relocation brackets to my 1999 XJ rear suspension (OME leafs and OME 60053L nitrocharger sport shocks).
With the additional equipment, my resting length is 22.5" of the 24.5" max extended shock length (no BPE and stock axle mounting on Chry 8.25).
I assume this will result in insufficient downtravel capability (~2") but would appreciate your input.
Also, I've felt the OME nitrocharger sports have been stiff onroad when fully unloaded. With all my camping gear, its much better.
Therefore, any input on new shocks (if needed) would also be appreciated.
Old October 25th, 2017, 08:00
BenWheelin BenWheelin is offline
Re: Rear Leaf Downtravel / Do I need new shocks?
Unbolt shocks at the bottom, flex to the max with whatever you have available, (I use a forklift) and observe where the shock mounts end up at full drop.
Do you still have a rear sway bar? It's become the first thing to go when I get in the back of one.
Old October 25th, 2017, 08:12
The rear sway bar has been removed.
Below are images showing the process you describe. The distance from the shock axle mount point to body mount point is 27" just before the tire comes off the ground. (shock extended length is 24.5")
AT RESTING HEIGHT WITH SHOCK FULLY EXTENEDED
PICKING UP REAR SUSPENSION WITH HI-LIFT
LEAF SPRING MAXIMUM AND SHOCK FULLY EXTENDED
Old October 25th, 2017, 10:31
VAhasnoWAVES VAhasnoWAVES is offline
your shock is definitely limiting droop with your new setup. shocks neither like to be limit straps nor bump stops. luckily, the leafs are a natural limit strap.
you can relocate your axle side shock mount to make more use of your shock, but that is only half the equation.
i would suggest setting a positive bump at full compression. then from there you can evaluate... will relocating the shock mount be enough, or do you need to purchase a new shock as well. or does bolting a new shock in fix your problem entirely? either way... i would still suggest a positive bump.
Old October 26th, 2017, 08:54
You'll get more drop to one side if you tuck a wheel on the other.
In other words, pick it up by the wheel/axle on one side and look at the other.
Old October 27th, 2017, 01:53
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Measure extended and collapsed length for travel.
And find correct size shocks for your application.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
LCoG Downtravel Metzroth Modified Tech Discussion 24 January 14th, 2011 20:12
WTB: 3.5" leaf packs and rear shocks boostamante SoCal For Sale 2 July 16th, 2009 18:40
Limiting downtravel bcmaxx Modified Tech Discussion 12 April 4th, 2009 20:55
i'm confused. how to get downtravel scorpio_vette Modified Tech Discussion 19 November 26th, 2007 06:41
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
