Old July 28th, 2017, 11:30
98lsxj 98lsxj is offline
98 LQ4 4L80 Build
I will be starting a LS swap next week with my brother and I will do my best to show the progress here. This is the setup as of now, I am open to ideas and appreciate any advice.
Engine
LQ4
BBK intake, Ls1 injectors, Texas speed cam, 243 heads, SBE
Transmission
4l80e stock convertor
231 transfer case with novak adapter to the 4l80
Plan to use my xj radiator that is an aftermarket 3 core with 3 electric fans
rear end swap to 8.8
GM computer with custom tune, Painless harness
Swap specific
Novak Engine Mounts
Novak headers
Novak transfer case cable
LS Simple front drive brackets
GM power steering pump and A/C compressor (will be adapted to xj components)
Still on the to figure out list
Drive line lengths
exhaust from headers back
plan to use corvette fuel regulator and return with 255l pump for fuel
Transmission mount?
air intake system will be figured out in the jeep
thinking of digital gauges off an obd2 dongle rather than doing a tach adapter
Old July 30th, 2017, 22:32
the_midwesterner the_midwesterner is offline
Re: 98 LQ4 4L80 Build
Before you order the Novak swap headers, look into c5 manifolds. They flow well, will bolt up to the head and may fit. I'm currently trying to confirm this now. I have the Novak swap headers and can't keep flange gaskets alive on the pass side. If the c5 manifolds fit, they can be had for like $60-80.
Old August 7th, 2017, 08:56
barney3 barney3 is offline
That would be great if the headers fit with the Novak mounts. I'm doing a 2005 lq4 swap and I'm about ready to order the Novak headers
Old August 31st, 2017, 09:32
So I did go with the novak headers and I am on the fence with the build quality. I think I had them ordered before I saw the suggestions. However they do fit well and give you a ton of room to work so I am happy I am not fighting with them.
Old September 1st, 2017, 18:30
[IMG][/IMG]
How it looks as of now. I got a lot done and need to figure some small thing out
Old September 1st, 2017, 18:42
[IMG][/IMG]
The lq4 and 243 heads, cam also installed
Old September 1st, 2017, 18:44
[IMG][/IMG]
The novak motor mounts are nice and worth the $ IMO
Old September 1st, 2017, 18:45
[IMG][/IMG]
LSSimple makes some nice front drive brackets
My buggy build....... well, continuation of a build. YELLAHEEP Colorado Chapter 39 November 18th, 2016 00:49
build a dream xj, what would you build poomero NorthWest Chapter 13 February 6th, 2016 07:44
Build 1 ton XJ on 39's 440swepty SEC For Sale / Wanted Forum 29 January 28th, 2012 16:16
New Waggy 44's Build (YOUR BUILD) 98XJLongBuild Modified Tech Discussion 20 November 11th, 2011 12:19
HP 44 Build-Up HoodRichXJ Modified Tech Discussion 17 March 22nd, 2005 20:34
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
