Old August 26th, 2017, 20:38
Rexj52's Avatar
Rexj52 Rexj52 is offline
Re: NP231 converting to NP242
Reading through this thread was very informative. My 89 has the 242 behind the aw4 and it's an awesome TC, but where I live we don't get enough rain or snow to really warrant the use of the FT mode. I will be looking to swap to a 231 though here in the future though if anybody still has one lying around and would like to trade.
Old August 27th, 2017, 14:07
lawsoncl lawsoncl is offline
Originally Posted by cLAYH View Post
Here is my experience in converting my '89 XJ from a 5spd/NP231 to a 5spd/NP242 and eventually to a Auto/NP242.
The wiring harness that came with the 5spd does not support the fulltime light, some wire tracing and splicing would need to be done to get it to work. I nver bothered looking into it. When I swapped in the auto I swapped in the wiring harness and it suported the fulltime light, all I had to do was put a bulb in the dash. This makes me think that if you already have an auto you should be able to find the wire for the full-time light and splice the pigtail from your donor vehicle onto it. But your '98 is probably much different from my '89.
I too enjoy my NP242! Great for winter driving and also for those gravel roads on the way to the trail! Keeps the locked backend from kicking out on the corners. I originally swapped mine in because I can easily buy NP242s for $100 with low miles(nobody wants them!). Its cheaper than rebuilding my NP231. Used NP231s run well over $400 if they are in decent shape, $250 if the chain needs replacing. Much more demand for the Np231 from the YJ/TJ crowd drives up the price.
I have a 242 sitting in the garage waiting for a quick rebuild and swap into my 89 MJ in place of the 231. I want 4wd full for the same reasons others have mention, especially since it's pretty easy to break the rear end loose on the truck. When I measured, the 242 was a little longer (I think it was an inch) which in my case is good since I'm marginal on engagement at the rear slip yoke.
Old August 29th, 2017, 06:56
90xj06's Avatar
90xj06 90xj06 is offline
i have a np231 and a transmission off a 90 in my garage. the front output bearing might be making noise. only does it in 4wd and did not in 2wd with the front driveline locked.
NP242 to NP231 Swap Question XJBill Modified Tech Discussion 15 March 18th, 2008 21:39
np242 np231??? scottkarduck Modified Tech Discussion 14 December 3rd, 2004 09:37
np231, np242 herreraxto OEM Tech Discussion 1 June 15th, 2004 08:05
using a np242 rear ds with a sye on a np231 XtremeJ Modified Tech Discussion 5 October 6th, 2003 12:22
Np242 vs 231 Differences Boz88xj Modified Tech Discussion 1 March 29th, 2003 14:46
