Old August 8th, 2017, 16:30
Nimrod's Avatar
Nimrod Nimrod is offline
Livin' the dream
Re: D&C Extreme Cage Install
Weird that Photobucket let you link to those images and then yanked them. And a bummer.
Photobucket sucks!
A whole lotta things that I never done. But I ain't never had too much fun!
Bill Kirchen and Billy C. Farlow, as recorded by Commander Cody and his Lost Planet Airmen
Old August 8th, 2017, 21:17
chris420 chris420 is offline
Is there another way to post photos?
Old August 8th, 2017, 21:22
Working on Photo's
Old August 8th, 2017, 21:56
Nimrod's Avatar
Livin' the dream
I've been using Tapatalk to post images since Photobucket started screwing things up. But there are other ways.
Old August 8th, 2017, 21:59
Old August 8th, 2017, 22:06
Old August 8th, 2017, 22:07
Old August 8th, 2017, 22:08
Old August 8th, 2017, 22:09
Old August 8th, 2017, 22:11
Ok so I hope those pics stick.
Old August 8th, 2017, 22:24
Originally Posted by Ghost View Post
From what I understand if you hole saw the floor and drop the cage down then you can safely weld up the whole cage. At least that is what I have seen people on here do in the past.
A lot of cage builders drop the cage through the floor to weld and pull it back up through the floor after. You will not be able to do that with this kit the main hoop sits on the unibody rail and the rear spreaders sit were the shackle mounts are. You would also need to weld the floor back up and the sheet metal is thin so its a pain in the but. You need to use .024 wire for the floor or you will blow through it.
Old August 8th, 2017, 22:28
Another idea would be to cut down the tubing and build rocker boxes that the cage can be welded to.
Old August 8th, 2017, 22:34
Originally Posted by hjeepxj View Post
Great idea, that's what I'm going to do!
I will post picks of my headliner when I get it back in I think you will be pleased with my idea. I am going to cut in half and make mounting points in the middle of the roof. I am also going to put Boom Mat underneath it maybe the thermal one not sure yet.
D&C Extreme Cage kits........ Timmy2XJS Modified Tech Discussion 21 September 30th, 2008 16:58
D and C Extreme Cage Kits Mdub Modified Tech Discussion 27 June 16th, 2008 23:10
D&C Extreme Cage jwtrapper Colorado Chapter 12 July 8th, 2007 17:46
XJ Cage (Like D and C Extreme) 93JXJ SEC For Sale / Wanted Forum 1 March 7th, 2007 06:14
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
