Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old July 16th, 2017, 21:49
kwlskr kwlskr is offline
Collision damaged xj and bent unibody
Just wondering if this i should attempt to fix this or not waste my time.... I've had the jeep like this since I bought and and used it as a daily driver for almost a year, just want to build a budget jeep for trails and fun...etc
Not very experienced in auto body or welding but i do have a can-do attitude! 😃
Old July 17th, 2017, 17:05
I am also wondering if anyone has any ideas on how to fix this?
Old July 18th, 2017, 14:57
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Re: Collision damaged xj and bent unibody
Can you fix it, yes!
Will it look good...probably not the greatest.
You can cut out the rockers and put in 2x6, cut and fold the rear fenders then try to smooth out the sheetmetal as much as possible.
Old July 18th, 2017, 19:07
Should I try to push out the dent? The rear seat support is kinked in
Old July 19th, 2017, 12:08
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Think that rear seat support might be something you can buy separately (like floorpans or door skins), or just go to a junkyard, cut that piece out of a wreck, and install in your rig via glue-and-screw.
(edit) forgot - if you splice in a new piece on that side, leave a couple inches of overlap for attaching to the existing one once you cut out the kinked bit...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old July 19th, 2017, 18:35
Sounds good! If I decide to tackle this I will definitely take pictures and post on the forum
WTB: Cheap Rear bumper with tire carrier / Prefer damaged/bent/ugly! downshift1 SoCal For Sale 3 February 4th, 2013 02:06
best way to repair damaged unibody frame rail? 90Pioneer OEM Tech Discussion 3 October 25th, 2010 09:26
beef up rear unibody after collision sharq Modified Tech Discussion 12 May 11th, 2009 22:02
Post Pics & Stories Of Yours/Your Friends Failed/Bent/Damaged Rock Rails IdeaMan Modified Tech Discussion 3 November 20th, 2004 18:18
collision of two Cherokee's 85Chief Non-Tech / Off Topic 13 September 6th, 2004 22:10
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
