Old April 30th, 2017, 11:32
RCP Phx RCP Phx is online now
Re: New issue, low to no oil pressure!
I finally got a return call from Basko Engines. Ray has been doing my machining/balancing work for me for over 40yrs. He said the 4.0 is notorious for eating cam bearings. That's the type of info I was trying to find out!
Tore the motor down last night(building a stroker), the cam bearings were indeed wasted! The crank journals didn't look as bad as I would have thought and the main/rod bearings were definitely not that bad.
Oil pressure issue dirtyjerseyjeep OEM Tech Discussion 9 January 6th, 2013 13:13
Oil pressure issue MudfrogK5 OEM Tech Discussion 35 November 3rd, 2010 10:48
Pressure Issue? 89heepxj OEM Tech Discussion 2 June 10th, 2009 12:09
Oil Pressure Issue nhrocker OEM Tech Discussion 6 September 17th, 2006 12:31
Oil Pressure Issue Jeff-97XJ OEM Tech Discussion 2 April 28th, 2005 07:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
