Old February 25th, 2017, 14:10
tricker tricker is offline
Re: 98 XJ Coil Driver
I am using an inline spark tester between coil and cap/rotor
Old February 25th, 2017, 14:26
90xj06's Avatar
90xj06 90xj06 is offline
this test leaves the actual coil in the circuit. it might just be your coil died
Old February 25th, 2017, 16:25
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
May want to see if the coil has power as well.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old February 26th, 2017, 11:27
I'm getting no ground switching at A7
Where do I go next?
thanks or the help so far!
Old February 26th, 2017, 12:25
if i put my spark tester inline from the coil to a good ground i get a faint spark....nothing when connected to rotor
Old February 28th, 2017, 05:14
Sidewinder CC's Avatar
Sidewinder CC Sidewinder CC is offline
Coil test procedures:
Cracked coil:
Old February 28th, 2017, 06:16
90xj06's Avatar
Where do I go next?
you will not be able to measure the ground switching with a multi meter. it happens in less than a second and typical meters will not register that. the typical pulse is in the 3.5 millisecond range. unless you can get an oscilloscope connected to it im going to say its working fine. and the coil is failed.
Old March 5th, 2017, 12:01
just to update because I dug through alot of threads over the past few months and hated finding no end threads
IT HAS STARTED AND RAN for about a day now, no issues discovered other than its still trying to find the right idle
after i started getting a little spark( by removing all the negative wires that attach below the coil and clamping them to the AC compressor mount) i quit messing with it for about a week
today i went and just turned the key and it started to run for a few second, then eventually started running close to normal again
I have no clue what worked- but thanks for everyones input, I have a sinking feeling that I may be back for help shortly
Driver Side Front Coil Rubbing 4jeep4 Modified Tech Discussion 10 November 13th, 2013 17:41
Wanted: Coil pack for 4.0 coil on plug Brandoson Arizona For Sale/Wanted 0 October 17th, 2012 21:45
front driver side coil spring perch snapped bijjim Modified Tech Discussion 1 June 8th, 2006 21:39
